PeterJWhite Posted September 15, 2006 Share #1 Posted September 15, 2006 Advertisement (gone after registration) The M8's lens mount is extended a bit from the body. I assume that this is to make space behind the sensor for whatever needs to be behind the sensor and keep the body as close as possible to the same depth as other M bodies. But this means that the macro adapter optics for the 90mm lens are now positioned further in front of the viewfinder on the M8 than on all other M bodies, by the thickness of the extended mount. Does anyone know if this will be a problem? Can it change the field of view in the 90mm frames? Link to post Share on other sites More sharing options...
Advertisement Posted September 15, 2006 Posted September 15, 2006 Hi PeterJWhite, Take a look here 90 macro compatibility question. I'm sure you'll find what you were looking for!
