hjsesq Posted March 10, 2008 Share #1 Posted March 10, 2008 Advertisement (gone after registration) Does anyone have experience using the Leica R adapter with an L1 and an R lens? My L1 operates fine with the Leica 14 -50 kit lens and I can turn it on with the adapter and an R lens installed, but when I push the exposure button nothing happens. Is there a setting on the menu or is it just incompatable? Thanks, Harris Link to post Share on other sites More sharing options...
Advertisement Posted March 10, 2008 Posted March 10, 2008 Hi hjsesq, Take a look here L1 with R adapter and R lens . I'm sure you'll find what you were looking for!
goodbokeh Posted March 10, 2008 Share #2 Posted March 10, 2008 Does anyone have experience using the Leica R adapter with an L1 and an R lens? My L1 operates fine with the Leica 14 -50 kit lens and I can turn it on with the adapter and an R lens installed, but when I push the exposure button nothing happens. Is there a setting on the menu or is it just incompatable? Thanks,Harris Yes, there is a menu item you have to set for the camera to fire without a lens attached. Because the R lens has no electrical connection to the L1 body, the camera interprets that no lens is attached. Be sure to have upgraded your L1 to firmware 2.0, that way the focus confirmation light will work with your R lens also. Link to post Share on other sites More sharing options...
hjsesq Posted March 10, 2008 Author Share #3 Posted March 10, 2008 Thank you - found the item on the menu and have now have it working. The software is updated. I assume you have been using R lenses with an L1 or Digilux 3. What has been your experience - any lenses in particular you recommend. Again thanks for such fast assistance. Harris Link to post Share on other sites More sharing options...
goodbokeh Posted March 10, 2008 Share #4 Posted March 10, 2008 Thank you - found the item on the menu and have now have it working. The software is updated. I assume you have been using R lenses with an L1 or Digilux 3. What has been your experience - any lenses in particular you recommend. Again thanks for such fast assistance.Harris I have used the 100mm f/2.8 macro Elmarit which turns into an equivalent of a 200mm. It's a nice combo but any R lens is nice to use. Link to post Share on other sites More sharing options...
