Guest moonwrack Posted March 7, 2008 Share #1 Posted March 7, 2008 Advertisement (gone after registration) Am I imagining it or am I right in thinking that the 50mm framelines on my M4-P are larger than those on my M6? The only external difference is that the M4-P viewfinder has a stepped front frame. Link to post Share on other sites More sharing options...
Advertisement Posted March 7, 2008 Posted March 7, 2008 Hi Guest moonwrack, Take a look here 50mm frame sizes on M4-P and M6 . I'm sure you'll find what you were looking for!
hans_s Posted March 7, 2008 Share #2 Posted March 7, 2008 You're correct. On the early M4P's with brass top plate the framelines for the 50mm lens are a bit wider. They are made for lenses foucusing down to 1 meter. On the later M4P's with the flush windows with zinc top plate the framelines are identical to the ones on the M6's; they are from then on adapted for lenses that focuses domn to 0.7 meters. Link to post Share on other sites More sharing options...
Guest moonwrack Posted March 7, 2008 Share #3 Posted March 7, 2008 Thank you, Hans_S. Problem solved. Link to post Share on other sites More sharing options...
