edtpm Posted February 29, 2008 Share #1 Posted February 29, 2008 Advertisement (gone after registration) Hi, I am going to purchase a good quality of UV filter for my DSLR Len. Just wondering whether Leica UV filter will be able to remove or reduce the flare? How about compare with B+W MRC UV filter? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted February 29, 2008 Posted February 29, 2008 Hi edtpm, Take a look here Will Leica UV filter remove flare? . I'm sure you'll find what you were looking for!
marknorton Posted February 29, 2008 Share #2 Posted February 29, 2008 I think most here would say the best filter to use on a lens is no filter and if we didn't need to use IR filters on the M8 we wouldn't use any filter at all. If you are shooting where flare is a problem, the extra air-glass surfaces are likely to make it worse, not better. Link to post Share on other sites More sharing options...
stunsworth Posted February 29, 2008 Share #3 Posted February 29, 2008 Totally agree with what Mark says. The only time I used filters on my film Ms was when I was shooting b&w - which I confess was the majority of the time. In fact the Noctilux instructions advised not to use filters with that lens. Link to post Share on other sites More sharing options...
Symeon Posted March 14, 2008 Share #4 Posted March 14, 2008 Basically you dont need UV for later Leitz optics but if you must try the B&W brand. Anyhow filtres do not really eradicate flare or other optical defects, lens multicoating does. Avoid small apertures and use a hood instead, it helps. Regards. Link to post Share on other sites More sharing options...
