echorec Posted February 17, 2008 Share #1 Posted February 17, 2008 Advertisement (gone after registration) Hi, does the MP work fine with the Summicron 50mm Dual Range? Thanks, Gunnar Link to post Share on other sites More sharing options...
Advertisement Posted February 17, 2008 Posted February 17, 2008 Hi echorec, Take a look here MP with DR Summicron? . I'm sure you'll find what you were looking for!
thomasw_ Posted February 18, 2008 Share #2 Posted February 18, 2008 Should be no problem. Link to post Share on other sites More sharing options...
telewatt Posted February 18, 2008 Share #3 Posted February 18, 2008 no problem at all!...do you have the lens?...If you like to buy it..be carfully with foggy lenses. regards, Jan Link to post Share on other sites More sharing options...
Guest maddin Posted February 18, 2008 Share #4 Posted February 18, 2008 Only thing to consider (besides the fog issue Jan mentions) that you should mount it set to infinity focus. I use it with the closeup goggles on MP, M7 (with the little pin unscrewed from the goggles) & M6 - no negative issues;) Link to post Share on other sites More sharing options...
echorec Posted February 18, 2008 Author Share #5 Posted February 18, 2008 Thanks guys, Yes, I have the lens, quite clean glass and I am looking at buying an MP. Link to post Share on other sites More sharing options...
Guest Joachim_I Posted February 18, 2008 Share #6 Posted February 18, 2008 does the MP work fine with the Summicron 50mm Dual Range? Works fine, see the first picture here. Link to post Share on other sites More sharing options...
jc_braconi Posted February 18, 2008 Share #7 Posted February 18, 2008 Advertisement (gone after registration) Take care about one thing : the position of the helicoidal ramp (looks like a hook) can match with the rangefinder wheel when you remove the lens from the camera. Check before outside of the body. Link to post Share on other sites More sharing options...
