bazza1_0 Posted February 16, 2008 Share #1 Â Posted February 16, 2008 Advertisement (gone after registration) Can anyone help me identify this Leica? My research of the serial Nr 145416 has been a bit confusing. I aquired it from my grandfather who was in the French Navy prior to and during WW2. Its said that he also worked for French intelegence. The lense has a serial Nr 121117, Leitz Hektor, 1:4,5 F - 13,5. Â Any help would be great. Â Barry Link to post Share on other sites More sharing options...
Advertisement Posted February 16, 2008 Posted February 16, 2008 Hi bazza1_0, Take a look here Identity Leica 111?. I'm sure you'll find what you were looking for!
brassia Posted February 16, 2008 Share #2 Â Posted February 16, 2008 seems III,Model F ,1934 doesn't have 1/1000 Shutter so is not IIIa, Model G. should have dioptre correction lever @ eyepiece Link to post Share on other sites More sharing options...
jc_braconi Posted February 16, 2008 Share #3  Posted February 16, 2008 Leitz Hektor, 1:4,5 F - 13,5. ??? must be 1:2.5 f 5,0 cm  should have dioptre correction lever @ eyepiece  It has. Link to post Share on other sites More sharing options...
fuchs Posted February 17, 2008 Share #4  Posted February 17, 2008 ??? must be 1:2.5 f 5,0 cm  No, he means the 135mm/4.5 Hektor, correctly labelled in pre-1960's fashion 1:4,5 f=13,5cm: the first figure being the relative aperture of the lens, and the second one after the "f=" being the focal length in cm  Cheers, Link to post Share on other sites More sharing options...
eyedeebee Posted February 17, 2008 Share #5  Posted February 17, 2008 ??? must be 1:2.5 f 5,0 cm   .  JC is right - the photo is of a 1:2.5 f 5.0 cm Link to post Share on other sites More sharing options...
jc_braconi Posted February 17, 2008 Share #6  Posted February 17, 2008 No, he means the 135mm/4.5 Hektor, correctly labelled in pre-1960's fashion 1:4,5 f=13,5cm:the first figure being the relative aperture of the lens, and the second one after the "f=" being the focal length in cm  Cheers,  You see a 135 on the picture ? Link to post Share on other sites More sharing options...
