Vuescan Raw question
innerimager
This is driving me nuts. I know I must be missing something simple. I have Raw scans, that are Tiffs. When I try to rescan them I select scan from file, bring them up, hit scan.....and I get a negative again. I can't get it to scan to a positive! What am I missing? thanks....Peter
Hi Peter,
I use XP2 a lot together with Vuescan and a Nikon 5000. No experience with RAW Files, though - I save them as 16 bit TIFF to work with them in Photoshop.
"Media" is set to "Color negative". I recommend using "Lock exposure" and "Lock film base color" as described here:
Advanced Workflow Suggestions
Also, in the "crop" tab I set "Buffer (%)" to 20. Under "Color", try setting "Black point (%)" to 0.001 and White point to 0.05.
Hope you like your scans & Best regards,
Stefan.
Thank you R2-D2!!
You're welcome!
Using chromogenic film like XP2, do I set it at color negative rather than B&W negative as appears to be the case?
Quote from the "VueScan User's Guide":
Transmissive media
When scanning film, this option indicates whether you're using positive film (i.e. slides), color negative, or black/white negative film. This option causes the default film type to be changed, but also sets up the scanner for scanning orange-colored media (i.e. color negatives) by exposing the green and blue channels more than the red channel.
(source)
So "Color negative" seems to be the appropriate choice.
Hi R2D2,
I disagree. When batch scanning, one should set these values as I posted and then use the curve tool in photoshop afterwards. Oh - talking about "crop" -20% "buffer" only works if you set it on maximum. Just my 0.02$, and I might be very wrong... ;)
One should set these values depending on the actual picture.
  • 2 weeks later...
The OP didn't mention "batch scanning"... But you're right: When scanning batches one must set these values for the whole batch (or for a subset of equally exposed frames in the batch, see [1]) in order to work effectively.
Where did you get these values from?
You might find the following article on highlight clipping interesting:
ColorNeg for mono - user notes part 3 | photostream
[1]
If you're using the same lighting for all the frames on the roll (or a subset of the frames), you can lock the color balance by scanning the brightest frame in the series and then setting the Input > Lock image colors option. This will lock the black and white points for the scene, and will produce consistent colors for all the frames in the series.
(from VueScan - Advanced Workflow Suggestions)
