CDodkin Posted 1 hour ago Share #1 Posted 1 hour ago Advertisement (gone after registration) As the M EV1 does not come with it's own stand-alone charger, and having sold the Leica charger with my M11 shortly after purchasing the M EV1, I was on the lookout for an alternative battery charger. I did consider buying the Leica model again, but it is insanely expensive, for what is, in reality, a pretty basic device. After some research I settled on the LEICA BP-SCL7, BC-SCL7 (24026, 24027) DUAL USB BATTERY CHARGER BY WASABI POWER This is a dual battery charger, that connects to your own USB power supply (Not a computer USB port), and will simultaneously charge two Leica batteries. I use mine with an Anker 140w USB power brick: https://www.amazon.com/Anker-Multi-Device-Charging-Advanced-Intuitive/dp/B0DFCH3C4W/ref=ast_sto_dp_puis?th=1 You can use the Wasabi supplied USB cable, or a suitable USB-C charging cable, to connect the Wasabi charger to your power brick, and the charger flashes two green LEDs when it powers up to show it's functioning correctly. You then add one or two Leica batteries, which indicated charging via individual red flashing LEDs. When charged, each LED turns green. Works as advertised, simple and easy to use, charging seems to take the same time as the OEM Leica charger, but I can do two batteries in the same time now! Costs around $40 - either from Wasabi direct, or via Amazon. https://www.wasabipower.com/collections/leica-bp-scl7/products/leica-bp-scl7-bc-scl7-24026-24027-dual-usb-battery-charger-by-wasabi-power You can put the $175 you saved towards that second Leica battery! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/425586-alternative-m-ev1-battery-charger/?do=findComment&comment=5897083'>More sharing options...
Advertisement Posted 1 hour ago Posted 1 hour ago Hi CDodkin, Take a look here Alternative M EV1 Battery Charger. I'm sure you'll find what you were looking for!
Lightwrangler Posted 8 minutes ago Share #2 Posted 8 minutes ago (edited) Here is an alternative for the european market in case someone is looking: Patrona BP-SCL7 Edited 7 minutes ago by Lightwrangler Link to post Share on other sites More sharing options...
