nvp Posted 14 hours ago Share #1  Posted 14 hours ago Advertisement (gone after registration) Hi Members of the Leica forum My 50mm Summilux f1.4 Black Chrome 11688 has a front focus issue when used at f/1.4 or f/2 on my Leica M11-P. If I use Live view I can pin the focus easily It is only when I use the mechanical range finder system that I have to go more towards infinity to achieve adequate sharpness. I have adjusted lenses in the past by take out shims and adding them when it be necessary. With this lens I am stumped as how to get the whole lens group closer to the film plane. This lens is similar to the 50mm Summilux f1.4 Black 11891 with optics and I also own this one It is perfectly sharp at all apertures from 1.4 to 16 through the mechanical rangefinder system Does anyone have any suggestions on how to repair the 50mm Lux Black chrome front focus issue Thanks nvp   Link to post Share on other sites More sharing options...
Advertisement Posted 14 hours ago Posted 14 hours ago Hi nvp, Take a look here Front focus Issue 50mm Summilux f1.4 Black Chrome 11688. I'm sure you'll find what you were looking for!
anickpick Posted 11 hours ago Share #2 Â Posted 11 hours ago Send the lens to Leica or DAG with instructions to calibrate it at open aperture. Â Link to post Share on other sites More sharing options...
sinjun Posted 11 hours ago Share #3  Posted 11 hours ago If your other lens works well with the rangefinder, it sounds like a lens rather than camera problem. It could be that the cam which contacts the rangefinder roller in the camera needs adjusting. I don't think this is a simple job, or that you will be able to fix it with shims. I have done approximate fixes by putting thin copper tape on a section of the cam contact surface, but with a lens like this it is best to get a proper adjustment by an expert. Link to post Share on other sites More sharing options...
nvp Posted 8 hours ago Author Share #4  Posted 8 hours ago The irony is that the lens obviously had an issue from day 1 It was in mint condition in its original box obviously because not being collimated correctly from the onset it never got used I have seen https://sangin1122.tistory.com/1681?category=792059 article and https://www.yukosteel.com/2021/06/disassembly-leica-summilux-m-50mm-f14.html but they are not detailed enough after the initial dismantling One of the forum members https://www.l-camera-forum.com/profile/98977-henners/ discusses it with the most detail and maybe has completely adjusted since his article. All my lenses work perfectly on all film and digital bodies except this 50mm Lux Black chrome It will sit in its original box until it is fixed ! Link to post Share on other sites More sharing options...
