Thanks to the latest firmware update, we can now adjust the WB fine-tuning settings. Yay!
I’m curious to hear what everyone’s doing with this new option
What in-camera WB fine-tuning adjustments are you using to get a more neutral color rendering, or something closer to the classic “Leica look”?
I’m not looking to change the overall character of the M11 files, just to tone down the magenta bias while keeping that signature Leica warmth and depth.
Would love to hear your experiences and preferred settings!
40 minutes ago, CDodkin said:
Someone explain to me how a fixed WB offset control can solve a variable tint offset issue with the M11 (and M EV1)?
The answer is that most of us have found it’s not a “variable tint” offset issue. While the precise value might have some variation, the average offset is very consistent and exists on every photo I take. Precision vs accuracy. The offset might not be a precise value, but it’s always inaccurate in the same direction.
It’s clearly present when I blast saturation. My photos are overwhelming red. So I drop the magenta until the colors are more neutral and then I revert the saturation. Always gives me a much more natural image.
So I always find I need a consistent reduction in the magenta. The new adjustment will ensure that I’m starting from “close to correct” so that the first step of every edit isn’t “do the same magenta reduction for every single photo just to actually even see the correct version of my image.” The yellow/blue is more subjective, I don’t find it as much of a problem and more a question of whether you like warmer or cooler photos by default.
43 minutes ago, Vsisishi68 said:
@wdahab
Out of curiosity, what setting did you make ?
I'm just blindly following the 15/5 rec up above and seeing how that comes out. Haven't done real testing yet.
Edit: okay just futzed a bit. The 15 toward green seems to be a good, helps a lot comparing where my older photos were. The +5 to yellow seems a bit stronger than I like. Not bad, possibly closer to where I'd want, but definitely a "I like warm colors" vs the more vintage "I like blue colors" that I sometimes like. I just switched to +3 yellow to balance that out a bit.
Edited by wdahab
I’m not sure. I’ll try the suggestions here and see what they do.
I never really had a great issue before. I generally set the balance by Kelvin and I presume that wasn’t affected since 5500K is presumably 5500K given that it’s a defined point on an international colour standard.
