Alexander108 Posted September 19 Share #1 Posted September 19 Advertisement (gone after registration) I just bought a preowned Leica Elmarit 1:2.8 / 24mm ASPH (11878) that came with a click on lens hood. As I am now more and more using a yellow filter I found that I can either have the lens hood on or the filter (B+W 022 Yellow 495). Do I muss something or is there a special filter that does not protrude (which would mean it cannot be easily removed)? Or is there a third party lens hood that wold work? Thank you! Link to post Share on other sites More sharing options...
Advertisement Posted September 19 Posted September 19 Hi Alexander108, Take a look here Leica Elmarit 1:2.8 / 24mm ASPH w/ lens hood does not allow filter. I'm sure you'll find what you were looking for!
Alexander108 Posted September 19 Author Share #2 Posted September 19 (edited) Solved it kinda brute force. I identified that the B+W filters outer diameter is just .2mm too big. Screwed it on a adapter ring, fixed to my little Proxxon lathe and took off .3mm. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Now the filter has a nice brass shiny touch which is hidden under the hood anyway and the hood now fits perfectly. Edited September 19 by Alexander108 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Now the filter has a nice brass shiny touch which is hidden under the hood anyway and the hood now fits perfectly. ' data-webShareUrl='https://www.l-camera-forum.com/topic/424356-leica-elmarit-128-24mm-asph-w-lens-hood-does-not-allow-filter/?do=findComment&comment=5865538'>More sharing options...
Siriusone59 Posted September 19 Share #3 Posted September 19 Thanks for posting about this issue. I have the same lens and hood, I've not had any problems using it with a Leica UVa filter but haven't tried any other filters on it...now I know what to expect or maybe look-out for. Those little locating protrusions at the top and bottom of the hood do require a bit of clearance for it to attach correctly. 1 Link to post Share on other sites More sharing options...
Alexander108 Posted September 19 Author Share #4 Posted September 19 vor einer Stunde schrieb Siriusone59: Those little locating protrusions at the top and bottom of the hood do require a bit of clearance for it to attach correctly. Well, they end up in a ring that the filter must go through. That is why I needed to bring down the entire diameter down to 57.5mm so it clears these two protrusions and the ring that follows. 1 Link to post Share on other sites More sharing options...
