timplog Posted September 12 Share #1 Posted September 12 (edited) Advertisement (gone after registration) Hey folks loving the Q43 but can't find where in the menu I could disable persistent frame lines in the EVF-seemingly stuck at 60. maybe I screwed something up when I assigned the 2 small buttons under the thumb rest to other things I found more useful-those being white balance and self timer. maybe my search terms weren't well worded but... thanks in advance and for reading! EDIT I cannot thank one of you for the telepathically delivered answer found in the menu under Digital Zoom which somehow wasn't set at 43 but was at 60mm-changing that setting to 43 solved the issue. Wow many thanks Edited September 12 by timplog new info update Link to post Share on other sites More sharing options...
Advertisement Posted September 12 Posted September 12 Hi timplog, Take a look here Q43 frame lines. I'm sure you'll find what you were looking for!
Elliot Harper Posted September 12 Share #2 Posted September 12 That’s menu 4, there is digital zoom item there. Probably you set it to be 60? Link to post Share on other sites More sharing options...
timplog Posted September 13 Author Share #3 Posted September 13 yeah thanks I probably inadvertently did that while fumbling around trying to reassign one of the small buttons with my XLG thumbs IMHO would be good if they associated the digital zoom menu with EVF frame lines somewhere for dummies like myself cheers! Link to post Share on other sites More sharing options...
timplog Posted September 13 Author Share #4 Posted September 13 I'd better read through that manual again there's a lot to learn Link to post Share on other sites More sharing options...
Elliot Harper Posted September 13 Share #5 Posted September 13 (edited) 13 hours ago, timplog said: IMHO would be good if they associated the digital zoom menu with EVF frame lines somewhere for dummies like myself This has been debated for a while. Not doing so allows you to see what is outside of the frame line via EVF. Besides, it gives you the feelings how M camera works Edited September 13 by Elliot Harper 1 Link to post Share on other sites More sharing options...
