Jan1985 Posted August 29 Share #1 Posted August 29 Advertisement (gone after registration) I'm now starting to use an external display together with the SL3-S via HDMI. The only problem I have is, that I can't find any setting in the menu which allows to turn on the info with all the information I see on the SL3-S display like aperture, ISO, shutter angle and so on.... Does anybody know if there is an option? Or can you generally just the pure image? Link to post Share on other sites More sharing options...
Advertisement Posted August 29 Posted August 29 Hi Jan1985, Take a look here Leica SL3-S - External HDMI Monitor - How to turn on info bar?. I'm sure you'll find what you were looking for!
LocalHero1953 Posted August 29 Share #2 Posted August 29 Which external monitor? Isn't that where you would normally look? It's a long time since I used one, (BM VideoAssist), but I recall managing everything from the monitor. Link to post Share on other sites More sharing options...
BernardC Posted August 29 Share #3 Posted August 29 49 minutes ago, Jan1985 said: Does anybody know if there is an option? Or can you generally just the pure image? You get a clean image. The only option is to turn the sound off or on (in case you mic is connected to the external recorder). Your external display may have options for showing zebras, frame rate, bit depth, double-tap to punch-in, sound levels, etc., but those are independent from what the camera shows you. The reason why those options aren't available in the HDMI output is because they would be burned-in to your image. Some early cameras with HDMI let you do that (not sure about Leica), but it could lead to recording unusable footage. 1 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 29 Share #4 Posted August 29 1 hour ago, LocalHero1953 said: Which external monitor? Isn't that where you would normally look? It's a long time since I used one, (BM VideoAssist), but I recall managing everything from the monitor. Ignore my post - I'm sure Bernard is right. Link to post Share on other sites More sharing options...
Jan1985 Posted August 29 Author Share #5 Posted August 29 vor einer Stunde schrieb LocalHero1953: Which external monitor? Isn't that where you would normally look? It's a long time since I used one, (BM VideoAssist), but I recall managing everything from the monitor. For filmmaking i rig up the S3-S a Bit with a cage, top handle and a 7 inch monitor. It’s more convinient for longer sessions. but with that hints I will do my Settings on the Internal display. 1 Link to post Share on other sites More sharing options...
