Einst_Stein Posted August 27 Share #1 Posted August 27 Advertisement (gone after registration) This technology can switch the color within 100ns. If replace the current on-sensor color filter, it has the potential to take color pictures with 4X resolution, or, a true monochome. It is a LCD, with color changing capability by the controled electronic. It does not need to have pixel structure. It can be plain uniform that the whole frame changing color at the same time. With 100ns response time, a colored picture would be taken by three exposures (or whatever, depends on the color seperation algorithm). The max shutter speed in color mode would be limited to 1/3000 second, or 1/10000 second in monocrhome mode. 1 Link to post Share on other sites More sharing options...
Advertisement Posted August 27 Posted August 27 Hi Einst_Stein, Take a look here Ferroelectric Liquid Crystal: Electronic controlled color filter . I'm sure you'll find what you were looking for!
FrozenInTime Posted August 27 Share #2 Posted August 27 See also JVC LCCS color filter combined with a monochrome CRT in a broadcast monitor https://www.earlytelevision.org/jvc_tm-l450tu.html Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 27 Share #3 Posted August 27 3 hours ago, Einst_Stein said: This technology can switch the color within 100ns. If replace the current on-sensor color filter, it has the potential to take color pictures with 4X resolution, or, a true monochome. It is a LCD, with color changing capability by the controled electronic. It does not need to have pixel structure. It can be plain uniform that the whole frame changing color at the same time. With 100ns response time, a colored picture would be taken by three exposures (or whatever, depends on the color seperation algorithm). The max shutter speed in color mode would be limited to 1/3000 second, or 1/10000 second in monocrhome mode. Sounds interesting. Can you give us a link to more reading? Link to post Share on other sites More sharing options...
Einst_Stein Posted August 27 Author Share #4 Posted August 27 (edited) Not much that I know for public yet. Try google? Or, start from here: https://www.mdpi.com/2073-4352/9/9/470#:~:text=Ferroelectric liquid crystals (FLCs)%2C also known as chiral,directors resulting in a variety of electrooptical effects. Edited August 27 by Einst_Stein 1 1 Link to post Share on other sites More sharing options...
