alanlwilder Posted August 25 Share #1 Posted August 25 Advertisement (gone after registration) Being a new owner of a Q3, I might be able to get a SF 26 TTL flash but I'm unsure if it has TTL capability with newer cameras like the Q3. I like it's size and the output is more than enough for my purposes. Can anyone provide an answer? The Leica recommended SF 40 TTL flash at under $700 is way too expensive for my limited use and it's a bit large on such a small camera. Link to post Share on other sites More sharing options...
Advertisement Posted August 25 Posted August 25 Hi alanlwilder, Take a look here Does the Leica SF 26 provide TTL flash on the Q3?. I'm sure you'll find what you were looking for!
ReneTielenburh Posted August 25 Share #2 Posted August 25 Yes. It does indeed has TTL capability on the Q3. I am using the SF26 also on the CL. In this case in combination with the TL Apo 60mm macro. cheers, Rene 1 Link to post Share on other sites More sharing options...
alanlwilder Posted August 25 Author Share #3 Posted August 25 24 minutes ago, ReneTielenburh said: Yes. It does indeed has TTL capability on the Q3. I am using the SF26 also on the CL. In this case in combination with the TL Apo 60mm macro. cheers, Rene Thanks Rene. A YouTube poster also confirmed it works on the Q3. I don't know why they discontinued such a handy little flash. Link to post Share on other sites More sharing options...
