I picked up a Leica SL this month and decided to try my 400mm Telyt on it ( shot with 350mm f4.8 profile) . Guess what ------> The results are superb  - great Leica contrast, wonderful Leica colors and sharpness.
I used both Leica adapters R to M and M to L - you see a little vignette that can be  taken care of.
The 400mm Telyt is so cheap to acquire nowadays and it's hard not to get one . I'm used to the button + slide focusing and the distance traveled is not as bad as the old 350mm f4.8.
Enjoy!
Posted (edited)
Here's the specs
Order nos. - 11960 - 11953-(complete set) . LLC - 197
Production era - 1968-1994 < 8,016 lenses
Variants - No-cam, ELC or ELW versions
Mount - Visoflex, Leica-M or Leica-R
Number of lenses /groups - 2 / 1
F stop range - f/6.8 - f/22
Closest focusing distance - 3.6 m / 9.84 ft
Smallest object field - 158 x 236 mm
Diaphragm setting /type - manual
Angle of view diagonal - 6 degrees
Filter type - Series VII
Accessories
Shoulder stock - 14182
Filter ring - 14165
Pistol grip -
Adapter - 22228 - 1974-19??
Materials -
Dimensions length x diameter - 384 x 78 mm / 15.12 x 3.07 in
Weight - 1830 g /4.01 lb
Inscriptions - LEITZ CANADA TELYT-R 1:6.8/400 MM 2XXXXXX
LEITZ WETZLAR 2XXXXXX LENS MADE IN GERMANY TELYT-R 1:6.8 / 400
LEITZ WETZLAR 2XXXXXX LENS MADE IN GERMANY TELYT 1:6.8 / 400
Edited by cnguyen
