Jammy Dodger Posted July 19 Share #1 Posted July 19 Advertisement (gone after registration) Not used the M11 for some time in the Studio but today I had some really strange behavior when using the Godox Pro11 trigger with the Leica M11. Every time I was firing the shutter I was getting a double flash from two of the three light set-up. I know TTL doesn't work so had all flashes in manual mode and when I tested each flash individually they worked fine but not when all three were fired simultaneously. I had never encountered this before. I solved the issue eventually by putting the Godox trigger in hotshoe legacy mode and it worked fine. More for info than anything else. Link to post Share on other sites More sharing options...
Advertisement Posted July 19 Posted July 19 Hi Jammy Dodger, Take a look here Strange behavior with Godox Pro11L today . I'm sure you'll find what you were looking for!
Photoworks Posted July 20 Share #2 Posted July 20 You are probably using a trigger not made for Leica, and the contact and internal electronics are interfering with the camera. The M11 only works with the Profoto trigger in TTL, and others only by using the single pin on the trigger. Link to post Share on other sites More sharing options...
