If I set the focus mode to AFc in the menu and the autofocus metering mode to "Tracking," I expect the focus rectangle on the monitor to stay at the position where I last half-pressed the shutter button. If the subject then moves or I pan the camera, the rectangle should stay on the focused subject.
Unfortunately, that doesn't happen. The rectangle always stays in the center and constantly focuses on new objects when I half-press the shutter button and pan the camera.
What am I doing wrong?
The D-Lux 8 instruction manual states:
TRACKING
This field metering variant helps in the capture of mov-
ing objects. The focus on the object in the focus frame is
continuously adjusted, once it is detected.
Aim the focus frame at the desired object
(by panning the camera shifting the focus frame)
Tap and hold the shutter button
or
Press the function button
(provided it was assigned the function AF-L or AF-L +
AE-L, see p. 106)
The camera focuses on the object.
Pan the camera to the desired cropped section
Note
The focus frame “tracks” the saved object and
focus is continuously adjusted.
This metering method focuses continuously, even if the
AF mode AFs was set.
It works for me if I activate tracking mode like this:  I press the subject it should focus on on the display BEFORE half-pressing. Now it tracks the subject where ever I point the camera within the frame that the subject is in. When I half-press now, it will focus on the subject.
As soon as you half press, the focus will stay at the point on the screen it set the focus on. I guess it works that way so it still adjust the right exposure, which wouldnt be the case when you half-press and then recompose (only maybe if you have AE-L / AF-L assigned to buttons but I didn't try that out).
Hope that helped :)
Thanks for your reply, it helped and I got it to work. I don't know exactly how but I first enabled the Touch-AF option.
It took a while to start tracking objects, I guess the algorithm needed some time to "learn" in order to get started, since it was the first time I used this AF metering mode on my camera.
I ended up disabling the Touch-AF option again, since I generally don't use it. I only need to half press the shutter button and hold it. When I release it, the crosshair turns yellow and keeps tracking and "sticking" on the subject. When I want to reset it, I press the middle button (the one in the center of the arrow keys), and it turns white and goes back to the last position.
Just one thing I need to add: for some reason, tracking does not work if you have any of the two monochrome film looks enabled. I remember that I switched to Vivid look before it started working.
