Good morning, I'm starting to organize the scanning of all my negatives.
I'm going to use a Bowen Illuminati, which has a PC cable for the flash.
Currently, I'm testing the system with a Pentax K5, but I want to make the reproductions with the M240 in full frame.
With the Pentax, I use a basic Rowi hot shoe with two PC outputs, and it's worked without problems.
Can I also use it on the Leica 240 without burning anything?
8 hours ago, rogxwhit said:
Piqued my interest!  Haven't found any inf about voltages but as a fail-safe I did find this (Wein Safe-Sync):
https://www.bhphotovideo.com/c/product/273330-REG/Wein_990_515_SSPC_Safe_Sync.html/?ap=y&ap=y&smp=y&smp=y&lsft=BI%3A514
good product, i wonder is my Rowi has circuit protection.........i doubt it. Maybe can i dismantle it?....
Hi i just tested the Rowi shoe mount.
Here a video on how to test trigger flash voltage:
TYHe Bowens illumitran measured 216V or so, at the pc terminal.
When connected to the Rowi shoe mount, the output voltage on camera side is 6V, so SAFE!, it has a circuit protection inside.
If i measure the top of the shoue mount it reads 216V, so voltage is just corrected to camera side, not the loop trough.
Thanks all!!
Well today is a strange say.
The Rowi hot shoe doesn't seems to make goos contact with the 240
I mean, it doesn't trigger the flash.....i guess is a mecanical problem. The viewfinder works ok, so all is clean on camera side.
