I noticed today that in between shots my M11-D shows the "Full" message in the viewfinder. The card is definitely not full and internal storage is not full. I have my save settings set to SD card only.
It is not every shot, it shows up maybe every 10 or so shots.
I double checked the SD card and every shot is saved properly so I am not losing any frames.
Anyone else seeing this?
Faced with this issue once. After that, a newer firmware was released, I've upgraded to the latest firmware, and since then no any signs of this problem (hopefully).
vor 16 Stunden schrieb dscdsc:
Same issue!
As I noticed it the first time, I thougth, that the SD-Card ist "full" but then the leds will show "sdfull".
It is a firmware-bug, I think.
Interesting, I haven't had this one but in this
post, my camera thought the internal memory was full when it was only about 30% full. Did yours go away or did you have to format it? I had to format it to let me shoot again. I wonder if the issues are related to each other and the way the camera is writing files or reading storage. FWIW after i formatted the internal storage and bought and SD card I haven't had the issue again.
Thanks for sharing your experiences. I am already on the latest FW and have done a factory reset a couple weeks ago. I will try formatting the internal and SD memory and see what happens. I don't recall ever formatting the internal storage ever since I got the camera.
