JTVS Posted March 8 Share #1  Posted March 8 Advertisement (gone after registration) I recently received one form the manufacturer and it works. Appears to be an identical knock-off of the Leica Micro Adapter-M. It was a bit tight mounting on a M10R, but then on the 2nd try no problem -- most likely a slight burr that went away. No play in fit to body or lens. The focus ring is very stiff -- not a Leica feel -- noticeably more than with the Zeiss 35mm 1.4 lens, but since it is the closest ring to the body and fine focus is OK. My copy works. Considering the price was $190.00 USD plus shipping, and that I don't expect to use it much, it is worth the price at 1/3 the real Leica price. Since there are no optics I might open it up and change to a lighter grease, but probably won't since the stiff focus makes it slower but not a precise problem. Link to post Share on other sites More sharing options...
Advertisement Posted March 8 Posted March 8 Hi JTVS, Take a look here Artra Lab micro adapter-m. I'm sure you'll find what you were looking for!
