PetPhoto Posted March 4 Share #1 Posted March 4 Advertisement (gone after registration) Going by the lack of actual dimensions online, the beseler cadet II enlarger was given a bellows stage and lensboard very similar, if not the same as the current Printmaker 35/67 enlarger.. In theory, is anything other then a home made negative carrier and possible hack saw work to make a the hole at the top of the bellows stage large enough to show the entire 645 negative be needed? Link to post Share on other sites More sharing options...
Advertisement Posted March 4 Posted March 4 Hi PetPhoto, Take a look here 35mm to 645 question. I'm sure you'll find what you were looking for!
BernardC Posted March 4 Share #2 Posted March 4 You will also need a new light source. The condensers won't cover 645, so you'll get huge vignetting. The edges of your negs may not get any light at all. I would look for a working medium format enlarger rather than butchering an enlarger that doesn't do medium format. Link to post Share on other sites More sharing options...
PetPhoto Posted March 4 Author Share #3 Posted March 4 you did notice teh spot where i said i have a complete 67c enlarger lamphouse with complete condensor lens sets to do both k120 and 35mm Link to post Share on other sites More sharing options...
BernardC Posted March 4 Share #4 Posted March 4 In that case, I suggest you start here: https://www.beselerphoto.com/parts/ You'll see full parts listings for the 67 and Cadet, which should tell you what you need to turn one into the other. Link to post Share on other sites More sharing options...
