On 9/26/2024 at 8:40 PM, EddieCheddar said:
By the way, if you want to use an ND Filter on the Q3 43, you cannot use the small thin "square" hood that comes with the camera -- it won't fit.
You'll have to use the optional "circle" hood shown here, instead.
Does the ventilated lens hood interfere with or appear visible in the viewfinder?
The Q series is an EVF camera, so you will never see a hood through the viewfinder (EVF).  If you do, it will be in your full resolution image.
M cameras are the ones that have concerns with viewfinder (OVF) blockage.
