John Hartman Posted January 30 Share #1  Posted January 30 (edited) Advertisement (gone after registration) Is there a way to trigger the SL-3 shutter using the Bulb setting wirelessly? Both Leica FOTOS and Capture One mobile allow the full range of shutter speeds to be used except B and T. (Some other camera maker apps do allow this, so I'm pretty sure it's not a technical issue.) Wireless devices such as the Pluto Trigger (which I own), MIOPS and Pocket Wizard can trigger using the Bulb setting, but they require a cable to be plugged into a remote release port of the camera. The SL-3 has a remote release port, but there don't seem to be compatible remote release devices for that tiny port, either from Leica or any third parties. It would seem that if I had the proper cable I could use my Pluto Trigger (which connects to the Pluto with a standard 2.5mm sub-mini plug). Does anyone know what the name/size/type of connector end is that goes into the Leica release port? I would be willing to have a custom cable made if I knew what type of connector to ask for. Any help or suggestions would be greatly appreciated.   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited January 30 by John Hartman Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/418938-sl-3-on-wireless-bulb/?do=findComment&comment=5748719'>More sharing options...
Advertisement Posted January 30 Posted January 30 Hi John Hartman, Take a look here SL-3 on Wireless Bulb?. I'm sure you'll find what you were looking for!
Photoworks Posted January 31 Share #2 Â Posted January 31 you can find this info with a search in the forum. Â You need a plug mal 3.5 TRRS Â in the mic or headphone ports 1 Link to post Share on other sites More sharing options...
John Hartman Posted January 31 Author Share #3 Â Posted January 31 Thanks, I saw the posts after I made this one. Â Jh 1 Link to post Share on other sites More sharing options...
