FrankU Posted January 16 Share #1 Posted January 16 Advertisement (gone after registration) My q3 28 viewfinder misbehaves; I found the viewfinder viewing control in the Menu; I dislike the Histogram when I compose, so I turned that off. At the same time I like to have the level shown, so I set that item to on. But for all my efforts, all I got : no histogram blocking my view , but that level just does not show up ever ... which is quite annoying going through the rough sea in the wind .... Is that a common problem? Maybe if I install the newest operating system this will go away? I will try that .... Any advice is welcome. I have zebra turned off and it does not interfere; great! But how about that level? Where did it go? FrankU Link to post Share on other sites More sharing options...
Advertisement Posted January 16 Posted January 16 Hi FrankU, Take a look here Viewfinder on Q3 28 misbehaves. I'm sure you'll find what you were looking for!
Roy88 Posted January 17 Share #2 Posted January 17 (edited) If I understand your situation correctly, the changes you made enable the different items to display. You cycle through what appears in the viewfinder by pressing the center button on the multi-button control. It will stay in whatever display configuration you choose until you hit the center button again while using the viewfinder. Edited January 17 by Roy88 Link to post Share on other sites More sharing options...
