Greetings, does anybody know if/when a RAW video output over HDMI is coming to Leica SL3? I would love to be able to record ProRes RAW on Atomos Ninja Ultra. It seems that currently only SL2-S is supported.
x
I have spoken to Leica and this is the response I received:
I have spoken with the experts in Germany and they have let me know It is technically not possible to transfer 8k video via  regular (the “old”) HDMI. They could not say if recording 4k ProRes  RAW will or can be added via an update in the future.
What are you trying to film that you need 8k RAW? I think only 2 cameras are even doing and you need supporting cables and drives.
It is often overkill, LOG is very good, but you will need to set WB and exposure correctly.
Honestly for my current needs LOG is enough.
I am working in high end VFX and at some point I want to do some green/blue screen work for a side project so raw would be good for the extra fidelity when keying.
Yes for the green screen the ProRes would be good, Aldo not RAW you can still record ProRes HQ to the Ninja.
keep in mind that h.265 is ok for capture in most cases, but when opening and closing the file for post-production the compression with degrade quickly, so it is better to convert to another format.
Even 10 h.265 read the blacks start to look green even after 8-10 reads.
