specialshade Posted January 2 Share #1 Posted January 2 Advertisement (gone after registration) Hello, does anyone have any experience of this. I have recently bought a used Leica SL (601?) - the original version. All the buttons work apart from the Fn button on the front, no matter what mode I assign to it it does not do anything, this is with both short presses and long presses. I have rebooted the camera and applied firmware version 4.1 to no effect. Any advice would be most appreciated. Thanks, Neil. Link to post Share on other sites More sharing options...
Advertisement Posted January 2 Posted January 2 Hi specialshade, Take a look here Leica SL Fn button not responsive . I'm sure you'll find what you were looking for!
Photoworks Posted January 3 Share #2 Posted January 3 if resetting the camera does not solve the issue, it may need repair. make sure the 4 info screens are active in the menu, reset should fix it 1 Link to post Share on other sites More sharing options...
specialshade Posted January 3 Author Share #3 Posted January 3 Thanks, what do you mean by the 4 info screens? Also do you mean reset the camera via the menu or reboot it by removing the battery etc? Link to post Share on other sites More sharing options...
Photoworks Posted January 5 Share #4 Posted January 5 in the menu there is a reset camera setting function, it will delete all the presets and restart the camera fresh In capture assistants, you can find info profiles, and you can change what you like to display. Link to post Share on other sites More sharing options...
