Mikmau Posted December 22, 2024 Share #1 Posted December 22, 2024 Advertisement (gone after registration) Hi, I’m experiencing very low FPS with the Profoto Connect PRO and Leica SL2/SL2s cameras. The SL2/SL2s are set to 6 FPS and perform perfectly, but when the Profoto Connect PRO is mounted and turned on, the FPS drops dramatically. Is there any way to resolve this issue? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted December 22, 2024 Posted December 22, 2024 Hi Mikmau, Take a look here SL2 and Profoto connect pro. I'm sure you'll find what you were looking for!
mokona Posted December 22, 2024 Share #2 Posted December 22, 2024 maybe your Profoto strobe cannot fire at 6 fps. What's your power setting on the Profoto? Link to post Share on other sites More sharing options...
Mikmau Posted December 22, 2024 Author Share #3 Posted December 22, 2024 Tried with profoto connect pro in set on Ttl and manually at minimum power, 0.1 on my b10, SL fires slower than 1 fps. Same settings with my canon r3, the b10 fire continuously without issues. Link to post Share on other sites More sharing options...
Photoworks Posted December 26, 2024 Share #4 Posted December 26, 2024 It is very much possible that the pre-flash delays the shutter. Is there a legacy mode on the trigger. it is the same with the godox. I use a godox/canon trigger in the studio. Flash is all manual anyway Link to post Share on other sites More sharing options...
bsmith Posted December 28, 2024 Share #5 Posted December 28, 2024 Just use the ProFoto Leica air remote Any ProFoto flash will fire at any fps ( if turned down from 1/1 the Connect is for automation photographers it’s best to always use manual on flash anyway. Link to post Share on other sites More sharing options...
