Rotary Processing Recipes
j. white
Let's start of thread for those using rotary processors for film. I'll start with a suggestion and a question:
I have used a combination of Tri-X developed in Rodinal using a rotary processor (a jobo) for several years. After extensive testing and experience, I have come to understand this combination very well. My recipe: For rolls with general contrast, shoot at iso 200 and develop in Rodinal at 1:49, using 150ml per 36 exposure roll, for 7.5 minutes at 70 degrees. This works very well for use with a condenser enlarger and with the lab I use for scans.
I love the look, but have just shot a number of rolls that would benefit from using a developer with lower acutance and the attendant grain - I'm thinking either HC-100 or D-76.
Can anyone suggestion a starting point for a dilution, developer amount, time, and temperture? Many thanks for your help.
-J.
Hi Andy, I'm sure you'll be blown away when you take that first roll of Astia off the spool and see the results in glorious colour.
Regarding Tri-X, I had lots of success (at least in my terms) using Xtol diluted 1:3 in a normal tank. Because there's even less active developer in a Jobo than a normal inversion tank you might want to drop that dilution to 1:2 or 1:1.
Looking back on my processing notes, here's another recommendation (using Jobo tanks):
Film: T-Max 100
ISO: 50
Developer: HC-110 Dilution D (1:9)
Quantity: 150ml per roll (in a small [2521] tank)
Temp: 70 degrees
Pre-Soak Time: 5:00
Development Time: 6:35
Again, this is for use with a condenser enlarger. I've also had good experience with using John Sexton's advise for increasing development times by 20% for use with diffusion enlargers. Additionally he has stated that he doesn't like the look of the T-Max films using this developer and I agree the negs have perhaps a bit more grain than is optimal for this film.
  • 2 weeks later...
D76 1:1 for 9.5 min at 68. Take 15% off for rotary processing ending up with 8 min. You need 4 oz each D76 and water.
Divide 8 by 1.4 to get a time for stock D76.
If you wish to use EI of 200, use 80% of above times
Thanks so much, Tobey.
After processing more than a dozen rolls, I've found that my ideal starting times for this combo are:
Film: Tri-X (400 TX)
ISO: 200
Developer: D-76 (1:1)
Quantity: 215ml per 36 exposure roll (in a large [2553] tank)
Temp: 70 degrees
Pre-Soak Time: 5:00
Development Time: 6:00
If you add a five minute water pre-wet, you can use the times published for inversion processing with any developer. Just be sure that, because of the small quantities of developer in a Jobo, you don't use less developer concentrate per roll than the manufacturer recommends. This is usually only an issue with extreme dilutions.
