roverover Posted November 24, 2024 Share #1  Posted November 24, 2024 (edited) Advertisement (gone after registration) I've noticed that the Top Display on my SL-3 behaves erratically. I have been experimenting with many ideas and settings, but haven't been able to ascertain how it is "supposed" to function. Sometimes mine lights up when i half press the shutter button. If i want to set a distance scale and I begin turning the focus ring, it then turns off in a few seconds before i can actually accomplish setting the focus where i want and often, i can NOT get the Top Display to come back on. Other times, it comes on and stays on for minutes at a time but then goes dark and i can't find a consistent way to get it to light up again! I haven't found any settings to Toggle it on to have it STAY on, has anyone else had issues with this? ...is this a bug or might i have a defective unit?     Edited November 24, 2024 by roverover Link to post Share on other sites More sharing options...
Advertisement Posted November 24, 2024 Posted November 24, 2024 Hi roverover, Take a look here SL-3, Question about the TOP DISPLAY functionality. I'm sure you'll find what you were looking for!
roverover Posted November 24, 2024 Author Share #2 Â Posted November 24, 2024 I am going to explore doing a hard Camera Reset to see if can get more reliable Top Display results and will post again in a day or 2 after more testing. Link to post Share on other sites More sharing options...
Jonathan Levin Posted November 24, 2024 Share #3  Posted November 24, 2024 It sounds like you are using manual focus mode. I think you have to soft press shutter release and focus. As far as it timing out, maybe thats a setting in power saving mode( can’t remember what its called) Maybe set that to go into standby mode after a longer time. If that makes sense. Link to post Share on other sites More sharing options...
roverover Posted November 24, 2024 Author Share #4  Posted November 24, 2024 (edited) 6 minutes ago, Jonathan Levin said: It sounds like you are using manual focus mode. I think you have to soft press shutter release and focus. As far as it timing out, maybe thats a setting in power saving mode( can’t remember what its called) Maybe set that to go into standby mode after a longer time. If that makes sense. Thanks, yes Manual Focus mode as the distance setting scale doesn't work in any other mode. There is a glitch that I experienced and have now done a Full RESET and now the camera seems to behaving normally with regard to the Top Display issue I posted. Edited November 24, 2024 by roverover 1 Link to post Share on other sites More sharing options...
