PeeDeeVee Posted November 8, 2024 Share #1 Posted November 8, 2024 Advertisement (gone after registration) So I've been trying to shoot a burst of shots with my q3. I was trying to capture some lightning. I put it into mf, 1/500,iso 800. I set the drive to 14fps But when I hit the shutter release there is a sec or two lag before the exposures start. Any idea how to correct this? Link to post Share on other sites More sharing options...
Advertisement Posted November 8, 2024 Posted November 8, 2024 Hi PeeDeeVee, Take a look here Q3 continuous drive mode. I'm sure you'll find what you were looking for!
ruskkyle Posted November 8, 2024 Share #2 Posted November 8, 2024 Sorry to ask the obvious, but was the self timer active? Link to post Share on other sites More sharing options...
PeeDeeVee Posted November 8, 2024 Author Share #3 Posted November 8, 2024 Lol... No... Self timer not active. Link to post Share on other sites More sharing options...
EddieCheddar Posted November 8, 2024 Share #4 Posted November 8, 2024 Hello PeeDeeVee. You may also want to try "Interval" mode. For example: Set the camera to take 1 photo every second for 60 seconds starting in 10 seconds. It's sort of like fishing. Toss your line in and see if you catch anything. 1 Link to post Share on other sites More sharing options...
PeeDeeVee Posted November 8, 2024 Author Share #5 Posted November 8, 2024 43 minutes ago, EddieCheddar said: Hello PeeDeeVee. You may also want to try "Interval" mode. For example: Set the camera to take 1 photo every second for 60 seconds starting in 10 seconds. It's sort of like fishing. Toss your line in and see if you catch anything. That's a useful technique but not for what I'm trying to do. I'm trying to take 14 or so frames as fast as the camera can take them - which looks like about 10 frames per second in DNG. It does seem to take them all but it doesn't start taking them the moment I press and hold the shutter. It lags almost a full second before it starts capturing. So in this instance I was shooting lightning over a cathedral. As soon as the lightning struck I hammered the shutter to capture as many frames as I could as fast as I could so I could get variations of the lightning. But I'd hit the shutter and I wouldn't get the first frame till almost a full second later when the lightning was gone. I'm thinking now, as I type, that perhaps I need even faster SD cards. I'm using Sandisk Extreme Pro UHS II 128Gb cards which I can capture 24fps at 47mp on my Canon. I'd assumed they would be fast enough Link to post Share on other sites More sharing options...
ruskkyle Posted November 8, 2024 Share #6 Posted November 8, 2024 I think that’s probably it. You need V90 SD cards ideally. I use the Angelbird ones and have no issues. Link to post Share on other sites More sharing options...
PeeDeeVee Posted November 9, 2024 Author Share #7 Posted November 9, 2024 Advertisement (gone after registration) I'll look into that but even UHS ii cards are faster than 90mb/s. I think they're 135 or so. Could be some other difference I'm not aware of Link to post Share on other sites More sharing options...
ruskkyle Posted November 9, 2024 Share #8 Posted November 9, 2024 I just tested on the settings you mentioned an at 15fps there is no delay. Link to post Share on other sites More sharing options...
PeeDeeVee Posted November 9, 2024 Author Share #9 Posted November 9, 2024 (edited) I was playing with it now and it worked as well. Only difference is that I switched to jpg. I think it may be dng vs jpg. I'm on a flight in a few minutes I'll check while in flight and post when I can. Thanks for your help! Edited November 9, 2024 by PeeDeeVee Link to post Share on other sites More sharing options...
PeeDeeVee Posted November 9, 2024 Author Share #10 Posted November 9, 2024 59 minutes ago, ruskkyle said: I just tested on the settings you mentioned an at 15fps there is no delay. I just played with it too and it is working perfectly now. I reloaded a user profile so I must have had something set that slowed it down. Thankfully all is well Thanks! 1 Link to post Share on other sites More sharing options...
