G19 Posted October 12, 2024 Share #1 Posted October 12, 2024 Advertisement (gone after registration) I normally remove the SD card from the camera and use the card reader slot on the back of the iMac to transfer the images via Apple's Image Capture app. Since upgrading to the new Sequoia when a card is inserted into the iMac, Image Capture just keeps flashing the images on and off the screen and then does not see them at all. If I use a normal card read I can access the files and drag the DCIM folder onto the desktop. Before I could also import the photos into an Apple Photos library on an external drive but having the same issue, will see the images but keeps flashing on and off and after three attempts just stops. I suspect it's a software issue with Apple reading the files, have formatted the card in the camera but still no joy. Anyone else having the same issue - did a search and could not find anything. Link to post Share on other sites More sharing options...
Advertisement Posted October 12, 2024 Posted October 12, 2024 Hi G19, Take a look here iMac Sequoia 15.0.1 Card Reader and Q2 . I'm sure you'll find what you were looking for!
Cogito Posted October 12, 2024 Share #2 Posted October 12, 2024 This appears to be an unsolved issue, no answer so far but thank you for giving a heads up not to upgrade yet. Link to post Share on other sites More sharing options...
luetz Posted October 12, 2024 Share #3 Posted October 12, 2024 Check Apple IMac compatibility with Sequoia 15.1 OS. This might point to your problem. Good Luck.... Link to post Share on other sites More sharing options...
luetz Posted October 12, 2024 Share #4 Posted October 12, 2024 Forgot to paste the results: macOS Sequoia (macOS 15) Supported Systems Specifically, the following Macs, available at the time the operating system was unveiled, are compatible with macOS Sequoia: Sequoia Supported Mac Subfamily Model ID iMac "Core i3" 3.6 21.5" (4K, 2019) Retina 4K, 21.5-Inch, 2019 iMac19,2 iMac "Core i5" 3.0 21.5" (4K, 2019) Retina 4K, 21.5-Inch, 2019 iMac19,2 iMac "Core i7" 3.2 21.5" (4K, 2019) Retina 4K, 21.5-Inch, 2019 iMac19,2 iMac "Core i5" 3.0 27" (5K, 2019) Retina 5K, 27-Inch, 2019 iMac19,1 iMac "Core i5" 3.1 27" (5K, 2019) Retina 5K, 27-Inch, 2019 iMac19,1 iMac "Core i5" 3.7 27" (5K, 2019) Retina 5K, 27-Inch, 2019 iMac19,1 iMac "Core i9" 3.6 27" (5K, 2019) Retina 5K, 27-Inch, 2019 iMac19,1 iMac "Core i5" 3.1 27" (5K, 2020) Retina 5K, 27-Inch, 2020 iMac20,1 iMac "Core i5" 3.3 27" (5K, 2020) Retina 5K, 27-Inch, 2020 iMac20,1 iMac "Core i7" 3.8 27" (5K, 2020) Retina 5K, 27-Inch, 2020 iMac20,1 iMac "Core i9" 3.6 27" (5K, 2020) Retina 5K, 27-Inch, 2020 iMac20,1 iMac "Core i7" 3.8 27" (5K, 2020; 5700/XT) Retina 5K, 27-Inch, 2020 iMac20,2 iMac "Core i9" 3.6 27" (5K, 2020; 5700/XT) Retina 5K, 27-Inch, 2020 iMac20,2 iMac "M1" 8 CPU/7 GPU/2 Ports 24" iMac (24", M1 2021) iMac21,2 iMac "M1" 8 CPU/8 GPU/4 Ports 24" iMac (24", M1 2021) iMac21,1 iMac "M3" 8 CPU/8 GPU/2 Ports 24" iMac (24", M3 2023) Mac15,4 iMac "M3" 8 CPU/10 GPU/4 Ports 24" iMac (24", M3 2023) Mac15,5 iMac Pro "8-Core" 3.2 27-Inch (5K, Late 2017) iMac Pro, Late 2017 iMacPro1,1 iMac Pro "10-Core" 3.0 27-Inch (5K, Late 2017) iMac Pro, Late 2017 iMacPro1,1 iMac Pro "14-Core" 2.5 27-Inch (5K, Late 2017) iMac Pro, Late 2017 iMacPro1,1 iMac Pro "18-Core" 2.3 27-Inch (5K, Late 2017) iMac Pro, Late 2017 iMacPro1,1 Link to post Share on other sites More sharing options...
coleica Posted October 14, 2024 Share #5 Posted October 14, 2024 On 10/12/2024 at 4:13 PM, luetz said: Check Apple IMac compatibility with Sequoia 15.1 OS. This might point to your problem. Good Luck.... Typically, Apple is very good of blocking upgrades if the new OS is not compatible with your hardware. At least, it has been my experience. Link to post Share on other sites More sharing options...
G19 Posted October 14, 2024 Author Share #6 Posted October 14, 2024 I’m not having any issues with my iMac running Sequoia 15.1 OS, which is compatible according to the list and has been updated. However, I'm experiencing a problem with reading SD cards. Whether using the rear slot or a USB hub, I can only access files through Disk Utility by locating the folder with the images and dragging them to the desktop. It’s possible that my iMac has a hardware issue with the rear card reader, but the problem persists with a USB card reader as well. Link to post Share on other sites More sharing options...
Tgd Posted October 27, 2024 Share #7 Posted October 27, 2024 Advertisement (gone after registration) I have the exact same problem with an M1 MacbookPro. I reported to Apple... And when I connect the Q3 to the Mac in USB, the connection is established at 480 Mb/s instead of 10 Gb/s... This is clearly an Apple USB bug ! Link to post Share on other sites More sharing options...
