Alparslan.kab Posted September 22, 2024 Share #1 Posted September 22, 2024 Advertisement (gone after registration) Hallöchen, habe seit kurzen eine MP 240 und bin an sich sehr zufrieden! manchmal fällt mir aber auf, dass der Verschluss nach dem Auslösen nicht spannt… vielleicht einmal in 300-500 Auslösungen ? Hat da jemand mit Erfahrung ? Vor allem würde mich interessieren ob das ein mechanischen oder digitales Problem sein kann… lg Link to post Share on other sites More sharing options...
Advertisement Posted September 22, 2024 Posted September 22, 2024 Hi Alparslan.kab, Take a look here Verschluss spannt nicht ?. I'm sure you'll find what you were looking for!
adan Posted September 22, 2024 Share #2 Posted September 22, 2024 (edited) Beachten Sie, dass dies das Internationale Forum ist. Und die „gemeinsame Sprache“ hier ist Englisch. Für diejenigen, die Deutsch bevorzugen, gibt es ein eigenes deutschsprachiges Forum. However, your problem sounds like a mechanical/electrical problem. One obvious thing to check - did you forget to remove the lens cap? Or accidentally set the lens aperture to f/16-22? If so, the camera, in auto-shutter mode (shutter dial set to "A"), will use a very long exposure (plus another equally long "dark exposure" to reduce noise) in attempting to photograph the dim or nonexistent light it is metering - BEFORE it allows the shutter to close and the shutter to wind on. Up to a minute for both (30 seconds + 30 seconds). It is also possible to accidentally set the shutter dial to: B - bulb exposure - shutter stays open as long as you hold the release button 8 sec(conds) timed exposure Both those setting are very close to the "A" setting, and it only takes a slight brush with a finger or sleeve or camera bag to shift the dial from A to those long-exposure settings. Edited September 22, 2024 by adan Link to post Share on other sites More sharing options...
Alparslan.kab Posted September 22, 2024 Author Share #3 Posted September 22, 2024 (edited) oh i am sorry, English is fine. is is definitely not a long shutter speed neither is the lens cap on the lens. It is definitely a problem with the shutter not moving back to its default position. Also noticeable since there's no Dot for metering on the shutter curtain anymore in these circumstances. After trying to take one exposure, which is pitch black, since the shutter is not able to open, it moves back to its default... defineatly not on automatic mode Edited September 22, 2024 by Alparslan.kab 1 Link to post Share on other sites More sharing options...
