PanoTools settings for 15mm Voigtlander?
footnoteblog
Great start. I'd been using Radial shift, and nothing was working right, until I realized it was Radial Luminance I was after...
Radial Shift = geometric correction for barrel distortion and colour fringing
Radial Luminance = correction for corner vignetting
If you only have vignetting in one colour - here cyan - then just alter the red channel.
The earlier quote for "R,G,B : 15, 4, 4" not only corrects for cyan in the corners, but also does overall vignetting correction (which all wide angle lenses suffer from, especially on digital sensors).
BTW there is also a "PTools for dummies" tool called "LensFix" - see Kekus.com
  • 2 weeks later...
Thanks!
So what are the CornerFix profiles, and are there some premade ones?
Oh and what coding should I use? Man, I can't believe I've never even gotten around to fixing this stuff. (Yes, I did get an IR cut filter shoved into this thing!)
