delander †Posted December 28, 2007 Author Share #21  Posted December 28, 2007 Advertisement (gone after registration) Pat,  In the top section of the box is a silver folder which contains the manual and the software discs including the Capture One disc,  HTH Jeff Link to post Share on other sites More sharing options...
Advertisement Posted December 28, 2007 Posted December 28, 2007 Hi delander †, Take a look here Capture 1 v4 - I am beginning to like it. I'm sure you'll find what you were looking for!
pat308 Posted December 28, 2007 Share #22  Posted December 28, 2007 Pat, In the top section of the box is a silver folder which contains the manual and the software discs including the Capture One disc,  HTH Jeff  Thanks. The moment I read silver folder I knew where it was.. Link to post Share on other sites More sharing options...
dhsimmonds Posted December 28, 2007 Share #23 Â Posted December 28, 2007 I use LR for my LC1 RAW images but C1v4 now for my DMR's DNG images, so I get a good comparison of speeed and workflow. C1v4 is much faster to use, but for me the ability to batch process makes it a winner every time. If only LR could batch process. Link to post Share on other sites More sharing options...
burkey Posted December 28, 2007 Share #24 Â Posted December 28, 2007 I've used C1 LE for a couple of months with both my Digilux 3 and RD-1 and have really liked the results. From what I've read here, under "license information" in the software and elsewhere I assumed that I had one upgrade available from my Capture 1 LE license. I downloaded v4 and to my surprise there isn't enough spaces to type in my original "key" into the activate area in v4. (More than likely I took my daily dosage of stupid pills and they're acting as expected.) But if you have any thoughts I'd appreciate the advice. (About the license key issue not the stupid pills.) Thanks. . . . Burkey Link to post Share on other sites More sharing options...
delander †Posted December 29, 2007 Author Share #25  Posted December 29, 2007 See post 6? Link to post Share on other sites More sharing options...
burkey Posted December 29, 2007 Share #26 Â Posted December 29, 2007 Yup, I read post #6. I should have mentioned that when I posted. When I log into Phase One and check under license management I find only the same "too large" code. I suppose I can email the folks at Phase One when and ask for assistance unless anyone else has a suggestion. Link to post Share on other sites More sharing options...
dhsimmonds Posted December 30, 2007 Share #27 Â Posted December 30, 2007 Advertisement (gone after registration) If you purchased your LE3.7 program it should have the license key on the CD disk packet and this should match the formatted spaces for registering C1 v 4. Link to post Share on other sites More sharing options...
burkey Posted December 30, 2007 Share #28 Â Posted December 30, 2007 Thanks, I'll give it try. . . . Burkey Link to post Share on other sites More sharing options...
