36 minutes ago, graphlex said:
Indeed, but awkward with a small card and no Live View.
The card doesn't have to be in perfect focus to be used as a white balance reference.
Lens: 1 m minimum focus distance, arm: 0,6 m. 😉
Edited by evikne
1 hour ago, graphlex said:
Great review! Two points I want to confirm: 1. Is white balance set in Fotos? 2. There appears to be no practical way to use a gray card without Visoflex, right? I’m mulling whether to trade my wonderful M10-D.
I am happy with my M11-D. I think the way you say "my wonderful M10-D" you should just stay with it. Sounds like you are happy with what you have.
The gray card doesn’t cover much of the frame but I’ll try it on my M10.
  • Haha 1
That is the sensible decision, but…
  • Haha 1
You don't have to do it in the camera. Just use the WB eyedropper in LR when you get home to your PC and copy the WB settings onto the other images taken in the same lighting conditions.
You're right...............if my M10-D hadn't turned out to be such a troubled child I would have kept it and not taken the trade-in offer against the M11-D, but with it having spent half it's life back at Wetzlar for too many reasons I reluctanltly let it go. I liked the sensor in the 10-D.
Having said that, and apart from missing the faux winding lever / thumb rest I am ok with the step up to the 11-D.
Hi There
You can change the white balance (and most other things) in Fotos - this works very well, if a little slower than one might like. I don't think you can use a grey card, even with the Visoflex, which doesn't have the menu system you might imagine - there was a lot of talk about this during the testing phase, I guess it might happen later, but currently the visoflex is just for taking photos and auto-review (nothing else).
But if you shoot DNG you're all cool about the white balance (or hot if you prefer it) - I either shoot daylight (in the day) or auto (in the night) I can fix anything in post (but it's vanishingly rare that I actually do so).
I didn't actually get an M10-D (although I was very enamoured with it) but resisting the M11-D was beyond me, and I don't regret it for a moment!
Hi Jono,
Interested that you couldn’t resist the M11-D.  I love my M10-D!
I’m interested in your comment above.  I thought from previous discussions that you set your temperature at 5,500 Kelvin and then adjusted in post?  Have you changed your approach?  I still hold to Auto white balance for everything and then change it in post if I need to.  I did previously set the same temp for everything as it gave consistency, but gave up after I found that I could rarely improve on what the camera did …
Cheers (& best)
John
Just now, IkarusJohn said:
Hi Jono,
Cheers (& best)
John
HI There John
I think what happened with the M10-D is that shortly after I finished testing it the M10-R fell into my lap, and I preferred the new sensor (highlight recovery and resolution). So I gave it a miss.
As far as white balance is concerned I've done the same for a few years - when out and about in the light I set it on daylight (sunny) because it gives me the ambient lighting (where AWB will try and bring it all back to the same thing). But also because it's like using a film stock - I could change it later, but in reality I very rarely do.
I find that if I leave AWB on by mistake then I end up changing it, but if I leave it on 'sunny' then I don't.
In mixed lighting I tend to use AWB (because it works well and after all, what is 'right').
All the best
  • 2 months later...
19 hours ago, lykafile said:
Beautiful photos as usual, jono. just curious what metering setting you are using with this camera
Thank you! generally I use:
Auto ISO max 12,500, minimum shutter 4x focal length
Manual White Balance (set to 'sunny')
1/3 stop under exposure
Spot exposure metering (half press and recompose if necessary)
mostly shot with a wide aperture.
best
best
Thanks @jonoslack. A quick question if I may. Are you using the 1/3 stop under exposure to protect highlights or do you find it gives a generally more "correct" exposure when using spot metering?
Thanks!
