Analogue full spectrum - with 6x6 photographic film - Rollei Infrared - from deep UV to IR 720 nm
(I'm still looking for a good 246 at a good price to do the modification)
  • 2 months later...
Posted (edited)
I went crazy and got an M246
I knew it wasn’t the perfect camera for my research, but I got some interesting results - all F8 - auto iso - Garda Lake from Desenzano (ovest to nord)
with a UV filter (range 370>400 nm) 1/45 - 3200 iso
with an orange filter to remove the haze (range 530>700 nm) 1/2000 - 320 iso
with a dark red filter (range 670>700 nm) 1/30 -1250 iso
with a 720 nm IR filter (range over 720 nm) 1/30" - 12500iso
P.S.
I read that the M9M is the best for IR photos, I wonder how it is possible to make a precise focus (it does not have live view).
Thanks
Toni
Edited by ph0toni
  • 2 weeks later...
4 hours ago, fotomas said:
Maybe off interest (if you not already know).
@fotomas Thanks for the link, I had no feedback on the various IR filters with M246, this post is clear!
... but it was complicated to translate from German to Italian :)
I have a Sony A7 full spectrum, I understood well the differences in speed (+12 stops) and file quality (much sharper). If I can't modify the M246, I will have to give up UV and IR
Maybe UV + visible ... similar to orthochromatic film is easy, but the wood effect of the foliage can only be obtained with the help of a tripod.
I took an M246 because I believe that only a mono sensor can be translated into grayscale with color filters. I tried many color filters with my standard Nikon Z7, the raw does not have a clear and logical response, if it is converted to black and white.
Thanks
With BW-colorfilters with digital color-cameras never worked for me. Better to do the BW conversion in the post. Can't tell for a full-spectrum camera.
But with an monochrome camera it's possible and you have to use them. Another comparison with contrast filters here. Could be I have posted the link before in one of your threads.
Since you can push the ISO on the M 246 up to 10.000 (at least for me with acceptable IQ) it could even be possible without a tripod in bright light, but in general a tripod helps a lot.
Unfortunately my Italian is rather basic😥
  • 4 weeks later...
I have been asking persistently if it is possible to modify the M series, the answer is that they all have the hot-pass filter glued in... and it is not possible.
So I will use my M246 with near UV and near IR filters
This is a comparison with a similar 24 Mpx RGB sensor
Thanks . Toni
