Some of you have used this accessory:
Product Code BRACKETANG12
The SRB Angled Shutter Release Bracket with 12” Vinyl Cable screws into the bottom of a Compact camera, which allows a 12" Vinyl Cable to be attached to help eliminate any possibility of camera shaking.
https://www.srb-photographic.co.uk/srb-angled-shutter-bracket-with-cable-8902-p.asp
why not simply use the phone app?
and it says "This Kit is for compact cameras that have a shutter release button that is angled to the top plate of the camera rather than being flat on the top, like a normal compact camera."
Edited by frame-it
vor 26 Minuten schrieb frame-it:
¿Por qué no utilizar simplemente la aplicación del teléfono?
y dice " Este kit es para cámaras compactas que tienen un botón disparador que está en ángulo con la placa superior de la cámara en lugar de estar plano en la parte superior, como una cámara compacta normal".
I have an iPhone 14 Pro and I don't know that app.
From what I'm seeing, this Kit is somewhere in between, there is another one for SLRs and another one for small compacts, this is the one that most closely resembles the aforementioned cameras in size.
  • jaapv changed the title to Stabilize cameras.
