TOM CADWALADER Posted July 28, 2024 Share #1 Â Posted July 28, 2024 Advertisement (gone after registration) I shoot video frequently and would like to record my stills to the SD card and the video to CFe card. Â Far as I can tell...I can't do that. Â Is that a correct assumption on my part? Link to post Share on other sites More sharing options...
Advertisement Posted July 28, 2024 Posted July 28, 2024 Hi TOM CADWALADER, Take a look here Record to CFe vs SD. on SL3. I'm sure you'll find what you were looking for!
LocalHero1953 Posted July 28, 2024 Share #2 Â Posted July 28, 2024 I don't have a SL3, just a SL2-S, but I use profiles. My user profiles for stills duplicate files between the two SD cards (SD1=SD2). My profiles for video are to record to SD1 and then to SD2. You might want to explore profiles similarly for the SL3. Oh, and welcome to the forum! 1 Link to post Share on other sites More sharing options...
Photoworks Posted July 29, 2024 Share #3 Â Posted July 29, 2024 4 hours ago, TOM CADWALADER said: I shoot video frequently and would like to record my stills to the SD card and the video to CFe card. Â Far as I can tell...I can't do that. Â Is that a correct assumption on my part? correct, the options are poor! Link to post Share on other sites More sharing options...
Jonathan Levin Posted July 29, 2024 Share #4  Posted July 29, 2024 On my SL3 video is recorded to the CFe. I don’t recall if I initially set this up that way. Link to post Share on other sites More sharing options...
TOM CADWALADER Posted July 29, 2024 Author Share #5 Â Posted July 29, 2024 16 hours ago, LocalHero1953 said: I don't have a SL3, just a SL2-S, but I use profiles. My user profiles for stills duplicate files between the two SD cards (SD1=SD2). My profiles for video are to record to SD1 and then to SD2. You might want to explore profiles similarly for the SL3. Oh, and welcome to the forum! I may explore using profiles to accomplish this. Â I think it could work. Â Thanks Link to post Share on other sites More sharing options...
LocalHero1953 Posted July 29, 2024 Share #6 Â Posted July 29, 2024 2 hours ago, TOM CADWALADER said: I may explore using profiles to accomplish this. Â I think it could work. Â Thanks I should add that I have never intentionally shot both stills and video to the same cards without reformatting. Video is a separate activity to photography for me; when I go to record video, I start with freshly formatted cards, and the same each time I go out to take stills. I have always assumed that the camera would not overwrite previous files when I change the saving pattern. If you are going to intersperse video and stills in the same outing, I suggest you test my assumption first! Link to post Share on other sites More sharing options...
