When reviewing images in Adobe Bridge or Photoshop is there an indicator for what autofocus mode was used for an image in the metadata or elsewhere? I'm testing the various settings—multi-field, zone, tracking, etc.—with very mixed results. It would be super helpful to be able to see what setting was being used on a particular image and which setting was successful or not in a given situation.
Another ask on the same topic: Nikon Studio has a setting that shows the location of the focus point using a red outline; several if using multi-field. That would be handy as well—particularly where a focus point was set on an image but failed.
Thanks.
use Exiftool.
its all in there unless Leica decided not to add it to their DNGS
AF-CPriority,AF-CSetting,AF-CSpeedTrackingSensitivity,AF-CTrackingSensitivity,
AF-CZoneAreaSwitching,AFSPriority,AFAreaMode,AFAreaModeSetting,AFAreaMode,AFAreaModeSetting,AFPointSelected,AFPointsUsed,AFTracking,AF-CPriority
etc etc etc
  • 8 months later...
I am sorry, but I can`t find it on my computer. Using Q3 DNG files.
ExifTool Version Number         : 12.96
File Name                       : L1018046.DNG
Directory                       : /Volumes/T9/Street/2025/250224
File Size                       : 81 MB
File Modification Date/Time     : 2025:02:24 13:24:42+01:00
File Access Date/Time           : 2025:02:24 17:30:38+01:00
File Inode Change Date/Time     : 2025:02:24 13:24:42+01:00
File Permissions                : -rwx------
File Type                       : DNG
File Type Extension             : dng
MIME Type                       : image/x-adobe-dng
Exif Byte Order                 : Little-endian (Intel, II)
Make                            : LEICA CAMERA AG
Camera Model Name               : LEICA Q3
Software                        : 3.0.0
Modify Date                     : 2025:02:24 13:24:42
Artist                          : Jiri Cvrk
Image Width                     : 9536
Image Height                    : 6344
Bits Per Sample                 : 14
Compression                     : JPEG
Photometric Interpretation      : Color Filter Array
Strip Offsets                   : 11545534
Samples Per Pixel               : 1
Rows Per Strip                  : 6344
Strip Byte Counts               : 69114550
X Resolution                    : 300
Y Resolution                    : 300
Resolution Unit                 : inches
CFA Repeat Pattern Dim          : 2 2
CFA Pattern 2                   : 0 1 1 2
CFA Layout                      : Rectangular
Black Level Repeat Dim          : 2 2
Black Level                     : 512 512 512 512
White Level                     : 16383
Default Crop Origin             : 4 4
Default Crop Size               : 9520 6336
Bayer Green Split               : 0
Anti Alias Strength             : 0.7
Best Quality Scale              : 1
Raw Data Unique ID              : 6E1F2A180D1802E9078E545B00000000
Active Area                     : 0 0 6344 9536
Opcode List 1                   : FixBadPixelsConstant
Opcode List 3                   : WarpRectilinear
Default User Crop               : 0 0 1 1
Preview Image Start             : 11060224
Preview Image Length            : 484530
Subfile Type                    : Reduced-resolution image
Jpg From Raw Start              : 146944
Jpg From Raw Length             : 10913020
About                           : Leica Camera AG
Rating                          : 0
Version                         : 1.0.0
Correction Already Applied      : False
Pitch Angle                     : -5.5999999046
Roll Angle                      : 0.2000000030
Focal Length 35mm               : 29.0000000000
Target Aspect Ratio             : 1.5025252104
Scaling Factor Height           : 0.9623432755
Valid Crop Corners              : True
Apply Automatically             : False
Normalized Crop Corners         : 0.0000000000, 0.0469036922, 0.9978825450, 0.0416699722, 0.9629269838, 0.9949496388, 0.0393840037, 0.9997934103
Copyright                       : Jiri Cvrk
Exposure Time                   : 1/500
F Number                        : 6.3
Exposure Program                : Manual
ISO                             : 500
Sensitivity Type                : Standard Output Sensitivity
Standard Output Sensitivity     : 500
Exif Version                    : 0300
Date/Time Original              : 2025:02:24 13:24:42
Create Date                     : 2025:02:24 13:24:42
Offset Time                     : +01:00
Offset Time Original            : +01:00
Offset Time Digitized           : +01:00
Components Configuration        : Y, Cb, Cr, -
Exposure Compensation           : -0.3
Max Aperture Value              : 1.7
Metering Mode                   : Multi-segment
Light Source                    : Unknown
Flash                           : Off, Did not fire
Focal Length                    : 28.0 mm
Serial Number                   : 5985422
Original File Name              : L1018046.DNG
Original Directory              : 101LEICA
Focus Distance                  : 65.535 m
File Index                      : 8046
Film Mode                       : Monochrome
WB RGB Levels                   : 0.4423326134 1 0.5707915273
Internal Serial Number          : (XJL) 2024:09:21 no. 0120
Multishot On                    : No
Focus Step Near                 : 280
Focus Step Count                : 2224
Flash Fired                     : No
Zoom Position                   : 280
Lens Attached                   : Yes
Lens Type Model                 : 01 f0
Aperture Value                  : 6.3
Shutter Speed Value             : 1/512
Sensitivity Value               : 2.21875
Faces Detected                  : No
White Balance Set               : Auto
WB Red Level Auto               : 2315
WB Blue Level Auto              : 1794
Orientation                     : Horizontal (normal)
White Balance Detected          : Daylight
Sub Sec Time Original           : 884
Flashpix Version                : 0100
Color Space                     : sRGB
Exif Image Width                : 9536
Exif Image Height               : 6344
Sensing Method                  : One-chip color area
File Source                     : Digital Camera
Custom Rendered                 : Normal
White Balance                   : Auto
Digital Zoom Ratio              : 1
Focal Length In 35mm Format     : 28 mm
Scene Capture Type              : Standard
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Lens Info                       : 28mm f/1.7
Lens Make                       : LEICA CAMERA AG
Lens Model                      : SUMMILUX 1:1.7/28 ASPH.
Lens Serial Number              : N/A
DNG Version                     : 1.4.0.0
DNG Backward Version            : 1.3.0.0
Unique Camera Model             : LEICA Q3
Localized Camera Model          : LEICA Q3
Color Matrix 1                  : 0.9872 -0.3529 0.0402 -0.5011 1.4105 0.3702 -0.0784 0.1685 0.7596
Color Matrix 2                  : 0.6602 -0.0788 -0.0864 -0.3621 1.2513 0.0657 -0.0683 0.1368 0.2922
As Shot Neutral                 : 0.4423326134 1 0.5707915273
Baseline Exposure               : 0
Baseline Noise                  : 1
Baseline Sharpness              : 1
Linear Response Limit           : 1
Camera Serial Number            : 5985422
Maker Note Safety               : Unsafe
Calibration Illuminant 1        : Standard Light A
Calibration Illuminant 2        : D65
Aperture                        : 6.3
Blue Balance                    : 0.570792
CFA Pattern                     : [Red,Green][Green,Blue]
Jpg From Raw                    : (Binary data 10913020 bytes, use -b option to extract)
Preview Image                   : (Binary data 484530 bytes, use -b option to extract)
Red Balance                     : 0.442333
Shutter Speed                   : 1/500
Create Date                     : 2025:02:24 13:24:42+01:00
Date/Time Original              : 2025:02:24 13:24:42.884+01:00
Modify Date                     : 2025:02:24 13:24:42+01:00
Image Size                      : 9536x6344
Light Value                     : 12.0
Megapixels                      : 60.5
Scale Factor To 35 mm Equivalent: 1.0
Circle Of Confusion             : 0.030 mm
Depth Of Field                  : inf (3.90 m - inf)
Field Of View                   : 65.4 deg (84.22 m)
Focal Length                    : 28.0 mm (35 mm equivalent: 28.0 mm)
Hyperfocal Distance             : 4.14 m
Done processing 1 files
Upgrade to the PRO-Version >ExifTool Reader Pro<
Available in the APPLE APP STORE
https://apps.apple.com/de/app/exiftool-reader-pro/id1640692796?mt=12
