yst Posted May 11, 2024 Share #1 Posted May 11, 2024 (edited) Advertisement (gone after registration) On the Leica D-Lux 7, the Exposure Bracketing function gives to choices: 1: -/0/+, or 2: 0/-/+ The 0/-/+ is my preferred sequence, and set on my D-Lux7 body! I try to set the same on the Leica CL body, but seems the CL only able to be on -/0/+; with the 0 compensation is on the middle of the sequence! Do I miss something in finding the 0/-/+ sequence on the CL menu? Or the CL menu doesn't give that choice?? I found the 0/-/+ exposure sequence is better, since the "presume correct" (0 compensation) should be fired first to capture the "right moment" of a moving or time sensitive action image... But I seem can't find the setting to change to 0 first on the CL? Edited May 11, 2024 by yst Link to post Share on other sites More sharing options...
Advertisement Posted May 11, 2024 Posted May 11, 2024 Hi yst, Take a look here CL body exposure bracketing question 🙏 . I'm sure you'll find what you were looking for!
Gregm61 Posted May 16, 2024 Share #2 Posted May 16, 2024 Your observation is correct. I have found no way of editing the sequence either. 1 Link to post Share on other sites More sharing options...
