M6ttl broken rewind
proforma
While in Paris this week, I hastily put a new roll of film in and after a few frames I noticed the rewind knob was not turning. I then tried to rewind and it had pressure and then it was spinning free. Turns out the knob would not turn to rewind the film.
Has anyone had this issue??
Is it costly to fix?
Greg
Hi Greg
Guess you have gone as far to open the back !;) I had a similar problem once but found that the free movement was when the film broke because it had torn the sprocket holes in the film. All I lost was the film left in the camera and the rewind was fine.:D
Sorry if yours is a broken winder.:eek:
TomR:)
  • 3 weeks later...
From my chats with techs, this is one of the mechanical weak spots of the M6TTL, the other being the frame counter. Apparently these systems were part of Leicas cost-cutting aspects of the design. For these reasons, one tech has described the TTL as "a problem waiting to happen."
That has not stopped me from owning two of them. I am a late-comer to the M and dare I say it, a heretic who thinks the shutter speed dial turns the correct way on this model.
-J.
