Hello,
I have noticed a darker band on the left hand edge of some scans of Ilford XP2 400. To try and rule out the scanner I have taken an image of the negative using my phone. It can be seen as a light band.
Was either f8 or f11, overcast day
I am not sure how the light sensitive chemicals are applied to film and where this is to be expected, or whether it may be a consequence of developing. Didn't record the shutter speed !
Any thoughts ?
Edited by IanS_?
  • IanS_? changed the title to Shutter issue ? Recent MP 2019ish
See attached images that hopefully make it clearer
Shutter needs a service. Do you recall which shutter speed you used? This is more likely at 1/1000 or 1/500. Might be ok to use at lower speeds until you get around to getting it serviced. Shoot a sequence from 1/1000 down and see which negs have the ‘shading’. Definitely not a processing error (edge markings are all ok)
Edited by PCPix
