DanielLeica Posted March 17, 2024 Share #1 Posted March 17, 2024 Advertisement (gone after registration) Hey guys, Wanted to check out a problem I have with my Q3 with you. My focus-ring has got stuck in the automatic mode, which limits my opportunity to use the camera immensely. I cannot turn it back to the M and it seems to be an issue of the button you need to press to "unlock" it. I have been in contact with the store where I bought it, but my problem is that I am traveling, so won't be home and able to turn it in for a few more months. Guess I am writing to see if any of you experienced the same and whether there is some kind of easy fix. Daniel Link to post Share on other sites More sharing options...
Advertisement Posted March 17, 2024 Posted March 17, 2024 Hi DanielLeica, Take a look here Problem with the focus-ring. I'm sure you'll find what you were looking for!
Siriusone59 Posted March 17, 2024 Share #2 Posted March 17, 2024 My Q does that occasionally, especially when I'm in a hurry. I've found that if I depress the button and try to turn the ring more into the auto position first, then rotate it back to manual focus it frees whatever is binding the button. I can actually feel the button depress just a hair more when it releases from auto. Yours could require more attention than that but it's worth a try. Link to post Share on other sites More sharing options...
DanielLeica Posted March 18, 2024 Author Share #3 Posted March 18, 2024 10 hours ago, Siriusone59 said: My Q does that occasionally, especially when I'm in a hurry. I've found that if I depress the button and try to turn the ring more into the auto position first, then rotate it back to manual focus it frees whatever is binding the button. I can actually feel the button depress just a hair more when it releases from auto. Yours could require more attention than that but it's worth a try. Thanks, I have had some problems with it before also, but not like this. I will try this as soon as I get back home. Link to post Share on other sites More sharing options...
GregM1421 Posted April 25, 2024 Share #4 Posted April 25, 2024 Any resolution to this? My Q3 focus ring just jammed in AF mode and I would prefer to not return it to Teaneck for what seems to be a really easy fix. Thanks. Link to post Share on other sites More sharing options...
Jaclo Posted May 9, 2024 Share #5 Posted May 9, 2024 Man, focus ring issues, another users SD card would not lock in place, what is going on with QC on the 6k camera? Link to post Share on other sites More sharing options...
