Peak Design makes a nice cube if that's what you are looking for. This is a picture of the SMedium cube which currently contains:
  • SL2-S and 35 APO
  • 75mm APO with screw on metal hood
  • Peak design strap right next to the body
  • Voightlander 35mm F1.2 Mk III and ND filter
  • small LED light for fill
I put the 24-90mm right next to the bag so you can see that with some rearranging it will fit.
I put this cube into my ULA Equipment Dragonfly pack which is much more comfortable than the other photo backpacks I have tried. The Peak Design pack carries more gear, however.
  • 3 weeks later...
  • 2 weeks later...
