Sharing this in case in anyone has a similar experience.
I updated the firmware to to 2.0.1. using the SD card method.  The upgrade looked like it went through completely.  However, when I tried connecting the Fotos app to it, it was complaining that the WiFi was not working.  I turned off the camera, but then when I turned it back on, I got a blank black screen (though the camera was actually "on").  I took out the battery a couple times, and that didn't resolve the issue.  I ended up removing the SD card, turned on the camera without the SD card, and it was behaving normally.  I then put back in the SD card and the camera worked fine, issue resolved.  (This fix was motivated here https://www.macfilos.com/2022/02/01/bricked-your-new-leica-m11-heres-the-quick-fix/, though I didn't need to delete the firmware file on the SD card.)
(Of note the Fotos app continued to have problems with WiFi, even after removing/readding the Q3.  I ultimately ended up resetting the Q3 and now it works normally.)
