carpediem007 Posted February 13, 2024 Share #1 Posted February 13, 2024 Advertisement (gone after registration) Hello everyone, I recently bought a R5 which works really well (all electronics & mechanical functions). I decided to get a Motor Winder-R (14 208) with fitting grip (14 308) both in mint condition with original packaging. When I load batteries into the winder and close the spring-lock, the drive starts to work and only stops when I remove the battery-holder. It doesn't matter whether I use the grip or whether the winder is attached to the camera or not. Has anyone had this problem and found a solution? I tried rechargeable and regular batteries... Thank you for any help / suggestions. Michael Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 13, 2024 Posted February 13, 2024 Hi carpediem007, Take a look here Problem with Motor Winder-R not stoping to work (off & on camera). I'm sure you'll find what you were looking for!
Eclectic Man Posted February 27, 2024 Share #2 Posted February 27, 2024 Sounds like there is a short somewhere which means the wonder is always turned on. Does it wind whichever of the two speeds is selected? Quote Link to post Share on other sites More sharing options...
carpediem007 Posted February 28, 2024 Author Share #3 Posted February 28, 2024 Hello Eclectic Man, thank you for trying to help, much appreciated. Yes, it shows the same behaviour whether set on one dot or two dots... Best, Michael Quote Link to post Share on other sites More sharing options...
