yst Posted January 22, 2024 Share #1 Posted January 22, 2024 Advertisement (gone after registration) Could someone help? When I am trying to re-familia with my D-Lux 7, I see on the display left top corner where displays the camera operation mode (e.g. A, P, S, M) has the "C1, C2, C3, Off" to de selected. However when I accidentally selected "off", that symbol display disappeared, and I could no longer able to go to select "C1, C2, C3, Off", how can I find or put that "C1, C2, C3, Off" selection display back on the screen? (Means I am no longer able to go back to select "C1", "C2", of "C3" that I customary set before...) Thank you in advance! Link to post Share on other sites More sharing options...
Advertisement Posted January 22, 2024 Posted January 22, 2024 Hi yst, Take a look here Need a help on D-Lux 7 control display disappearance. I'm sure you'll find what you were looking for!
DaveMo Posted January 22, 2024 Share #2 Posted January 22, 2024 (edited) I just had a look at my Typ109 menus and select "wrench C" on then in the Custom menu list and scroll down to "Utilize Custom Set Feature" click on it and it should allow you to access "C1,C2,C3 off". Thanks, Dave Edited January 22, 2024 by DaveMo Link to post Share on other sites More sharing options...
yst Posted January 22, 2024 Author Share #3 Posted January 22, 2024 2 hours ago, DaveMo said: I just had a look at my Typ109 menus and select "wrench C" on then in the Custom menu list and scroll down to "Utilize Custom Set Feature" click on it and it should allow you to access "C1,C2,C3 off". Thanks, Dave Thank you Dave, I did see that "Just.Set Mem", although it only has "C1, C2, C3" to select, and when I select one of the three, the icon of "C1,C2,C3 off" is still not able to be back on the back of the camera display screen ! Something I am not able to do correctly, I guess, what should I do? Also the right side vertical manure select bar on the back of the screen is also missing, which I could no long find is even after hours of searching... therefore, I can go to select on that fn bar for many features... I don't know what I did to have this fn bar gone? Link to post Share on other sites More sharing options...
DaveMo Posted January 22, 2024 Share #4 Posted January 22, 2024 (edited) Thanks for reply Yau-Sun, You might be better doing a reset on the camera as it sounds like something has got messed up in the settings. Give that a try and let me know if it works. I'm using my Typ109 as a basis so there could be some other "stuff" in the menu I'm not aware of. Edited January 22, 2024 by DaveMo Link to post Share on other sites More sharing options...
yst Posted January 23, 2024 Author Share #5 Posted January 23, 2024 5 hours ago, DaveMo said: Thanks for reply Yau-Sun, You might be better doing a reset on the camera as it sounds like something has got messed up in the settings. Give that a try and let me know if it works. I'm using my Typ109 as a basis so there could be some other "stuff" in the menu I'm not aware of. Thanks Dave, I am afraid of losing all the settings done on "C1, C2..." if making a camera reset. Still trying to find if there's a way on the menu allows to recover the disappeared icons and the right side fn bar settings... ? Link to post Share on other sites More sharing options...
DaveMo Posted January 23, 2024 Share #6 Posted January 23, 2024 Hi, Sorry I could not be more help to you, please let me know if you get it worked out. Dave Link to post Share on other sites More sharing options...
