mrkennethtong Posted January 3, 2024 Share #1 Posted January 3, 2024 Advertisement (gone after registration) Instead of asking the Waiter to fiddle with the Q3, I figure better just buy a Tripod and use LEICA FOTOS APP to take pictures etc. Is JOBY still the clear choice for something portable or has the world moved on from this?! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/386731-which-portable-tripod-for-leica-q3/?do=findComment&comment=4971612'>More sharing options...
Advertisement Posted January 3, 2024 Posted January 3, 2024 Hi mrkennethtong, Take a look here Which Portable Tripod for Leica Q3? . I'm sure you'll find what you were looking for!
prk60091 Posted January 3, 2024 Share #2 Posted January 3, 2024 platypod with handle - a little more costly but way more stable 1 Link to post Share on other sites More sharing options...
mrkennethtong Posted January 3, 2024 Author Share #3 Posted January 3, 2024 2 minutes ago, prk60091 said: platypod with handle - a little more costly but way more stable Thing looks great, JOBY was cool ten years or so ago, but you sure it is more stable than when you open the legs of the JOBY right?! Link to post Share on other sites More sharing options...
mrkennethtong Posted January 3, 2024 Author Share #4 Posted January 3, 2024 5 minutes ago, prk60091 said: platypod with handle - a little more costly but way more stable Will get the extreme even though the Ultra more than meets the specs of our Camera. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/386731-which-portable-tripod-for-leica-q3/?do=findComment&comment=4971650'>More sharing options...
Anbaric Posted January 3, 2024 Share #5 Posted January 3, 2024 (edited) You may want to take a look at the classic Leica Tabletop Tripod: http://jeffmellody.com/blog/2014/4/21/leica-table-top-tripod-review They've been making this for ever with small variations, so you don't need to pay current prices. The legs can still be found for £50-60 GBP, and the heads for about the same, or a bit less. You don't have to get the tall head shown in the above link, which was designed to allow an M (or screwmount) camera with the tripod socket at one end of the base plate to be mounted in portrait mode, though the length is handy if you want to use it as a chest pod. Leica made shorter heads too, and standard third party heads will fit. Because of the unusual design with legs that rotate into place instead of unfolding, this may be the most solid tabletop tripod ever made. You can't adjust the height, though, except by changing the head. Edited January 3, 2024 by Anbaric 1 Link to post Share on other sites More sharing options...
Guest Posted January 3, 2024 Share #6 Posted January 3, 2024 (edited) 13 minutes ago, Anbaric said: You may want to take a look at the classic Leica Tabletop Tripod: http://jeffmellody.com/blog/2014/4/21/leica-table-top-tripod-review They've been making this for ever with small variations, so you don't need to pay current prices. The legs can still be found for £50-60 GBP, and the heads for about the same. You don't have to get the tall head shown in the above link, which was designed to allow an M (or screwmount) camera with the tripod socket at one end of the base plate to be mounted in portrait mode, though the length is handy if you want to use it as a chest pod. Leica made shorter heads too, and standard third party heads will fit. Because of the unusual design with legs that rotate into place instead of unfolding, this may be the most solid tabletop tripod ever made. You can't adjust the height, though, except by changing the head. That thing is surprisingly heavy, which can be a pro or a con. The last head I purchased has a rough movement; my two previous ones were perfectly smooth - watch out for sample variation. The Platypod can be useful (I have several, including use as a base for flashes). I'm using it less than I had expected, less than 10% of my tripod/monopod/... applications. It does excel in portability and for the purpose of 'tripod police avoidance', as stated. Also nice for ground-level and tabletop applications. All my gorilla pods broke after a couple of uses. The joints loose tension, and the whole thing will then simply not bear any load and has to be discarded. Edited January 3, 2024 by mzbe Link to post Share on other sites More sharing options...
Marc B-C Posted January 3, 2024 Share #7 Posted January 3, 2024 Advertisement (gone after registration) I have a Q2 and used to have a Gorillapod. however I switched to the Gitzo Mini Traveler Tripod. This is a) not cheap, but b) a superb bit of kit. It is so stable and well built. Thoroughly recommended and one of my favourite accessories. For your apparent needs I would suggest the Gitzo. Note the link is to the UK site https://www.gitzo.com/uk-en/gitzo-mini-traveler-tripod-kit-black1-gktbb1/ 1 Link to post Share on other sites More sharing options...
BruceRH Posted January 3, 2024 Share #8 Posted January 3, 2024 The RRS Pocket Pod is very nice, light and compact. https://www.bhphotovideo.com/c/product/1301001-REG/really_right_stuff_tfa_01_ultra_pocket_pod.html/?ap=y&ap=y&smp=y&smp=y&lsft=BI%3A514&gad_source=1&gclid=EAIaIQobChMI3ICzxtDBgwMV0FN_AB32XQHiEAQYASABEgKKHfD_BwE 1 Link to post Share on other sites More sharing options...
Einst_Stein Posted January 3, 2024 Share #9 Posted January 3, 2024 https://www.bhphotovideo.com/c/product/1411323-REG/field_optics_research_ft5021a_microlite_ft_5021a_aluminum_tripod.html or Leica tablepod or both 1 Link to post Share on other sites More sharing options...
clasami Posted January 3, 2024 Share #10 Posted January 3, 2024 https://www.manfrotto-shop.de/Shop/Artikel/Manfrotto/MTPIXI-B_Pixi_Mini-Stativ_schwarz/128312 Small, light, stable. 1 Link to post Share on other sites More sharing options...
Marc B-C Posted January 3, 2024 Share #11 Posted January 3, 2024 (edited) 1 hour ago, clasami said: https://www.manfrotto-shop.de/Shop/Artikel/Manfrotto/MTPIXI-B_Pixi_Mini-Stativ_schwarz/128312 Small, light, stable. I tried two of those and on each the head would not lock properly using my Q2 at a tilt and so were returned. They do get some good reviews but based on my two samples I question the build quality consistency . Edited January 3, 2024 by Marc B-C 1 Link to post Share on other sites More sharing options...
ianforber Posted January 3, 2024 Share #12 Posted January 3, 2024 I have the Leica tabletop tripod with the long head. It’s a great bit of kit but the shape of the legs mean it’s a real pain to fit into a camera bag. I’ve heard great things about Leofoto mini tripods but decided not to buy one because my new Heipi tripod has a built-in mini tripod. When in doubt though, just buy Gitzo. 1 Link to post Share on other sites More sharing options...
hedleyw Posted January 3, 2024 Share #13 Posted January 3, 2024 Z Tripod Head Move Shoot Move Milky Way Panorama Photography (Z Mount) https://amzn.eu/d/8ic3Hip Very light and folds flat, plenty of reviews on YouTube. Designed for astrophotography but would work well on a flat surface, no ball head required. 1 Link to post Share on other sites More sharing options...
liggy Posted January 3, 2024 Share #14 Posted January 3, 2024 (edited) For all purpose light duty from relatively big to small I still favor the PD carbon fiber tripod. I typically use it without the center column so it can go really low. For when I am purely using it as a tabletop tripod I like the Benro. https://benrousa.com/tablepod-kit-with-arca-swiss-style-camera-plate-and-smartphone-adapter/ I have a couple of Gorillapods but mostly use them for lights and iPad / iPhone these days. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited January 3, 2024 by liggy 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/386731-which-portable-tripod-for-leica-q3/?do=findComment&comment=4972217'>More sharing options...
NorthantsRob Posted January 3, 2024 Share #15 Posted January 3, 2024 1 hour ago, ianforber said: I have the Leica tabletop tripod with the long head. It’s a great bit of kit but the shape of the legs mean it’s a real pain to fit into a camera bag. I’ve heard great things about Leofoto mini tripods but decided not to buy one because my new Heipi tripod has a built-in mini tripod. When in doubt though, just buy Gitzo. I bought the Gitzo Mini Traveller Tripod (GKTBB) to use with my Q3. 1 Link to post Share on other sites More sharing options...
mrkennethtong Posted January 4, 2024 Author Share #16 Posted January 4, 2024 Gitzo thing looks the best and the lightest in the Game! 1 Link to post Share on other sites More sharing options...
mrkennethtong Posted January 4, 2024 Author Share #17 Posted January 4, 2024 14 hours ago, Anbaric said: You may want to take a look at the classic Leica Tabletop Tripod: http://jeffmellody.com/blog/2014/4/21/leica-table-top-tripod-review They've been making this for ever with small variations, so you don't need to pay current prices. The legs can still be found for £50-60 GBP, and the heads for about the same, or a bit less. You don't have to get the tall head shown in the above link, which was designed to allow an M (or screwmount) camera with the tripod socket at one end of the base plate to be mounted in portrait mode, though the length is handy if you want to use it as a chest pod. Leica made shorter heads too, and standard third party heads will fit. Because of the unusual design with legs that rotate into place instead of unfolding, this may be the most solid tabletop tripod ever made. You can't adjust the height, though, except by changing the head. Grey one really pretty. Link to post Share on other sites More sharing options...
clasami Posted January 4, 2024 Share #18 Posted January 4, 2024 13 hours ago, Marc B-C said: I tried two of those and on each the head would not lock properly using my Q2 at a tilt and so were returned. They do get some good reviews but based on my two samples I question the build quality consistency . Mine is rock steady - also with cameras and lenses a lot heavier than the Q2. So it must have been just your luck, or their QC broke down. 1 Link to post Share on other sites More sharing options...
mrkennethtong Posted January 5, 2024 Author Share #19 Posted January 5, 2024 (edited) Bought this one as well on your recommendation. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited January 5, 2024 by mrkennethtong 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/386731-which-portable-tripod-for-leica-q3/?do=findComment&comment=4974104'>More sharing options...
mhasman Posted January 5, 2024 Share #20 Posted January 5, 2024 It looks stunning. Wish there is quick mount plate. Link to post Share on other sites More sharing options...
