I’m aware that the sf20 is fully compatible with the M6 TTL and the voltage of the flash is not too much for it, however I’m wondering if using the flash would add any wear and tear on the meter causing it to possibly fail sooner than it may if not using the flash? With the current state of repair I’d rather not put any more risk into the meter failing than needed.
